Brake Pedal is Hard, What Happens Next?
I have been having this problem with my '91 2WD on and off for at least a year, but more frequently since the weather cooled down. I'm thinking it's probably time for a new master cylinder, but I'm no rush to fix it if I can get another few months of driving out of the old one.
So my question is, how dangerous is it to drive around like this, what happens when the MC fails, and what kind of time line am I looking at before I'm gonna need to do something?
As it is, I only have the brake pedal go hard maybe one time out of ten, and it still seems to stop the truck OK. Why is it that the problem can come and go like this? Also, it it a difficult or expensive job to fix?
I would check the vacuum line going to it first, second, it is somewhat difficult to replace but not too hard, third, the brakes can fail if the MC fails, but if its a vacuum leak on the MC, which it sounds like ,then it will just be harder to push that brake pedal to the floor. The problem can be a leak in the rubber on the MC in the dash, the vacuum line going to it, or even the rubber boot in the front of the MC.
I've never had a master cylinder go "hard", so to speak. I've always lost brake pedal when they fail. I'd start looking at calipers or wheel cylinders seizing up.
Hmmm. Interesting.
I remember my 78 Corolla doing this a few times back in the day, but I just ignored it and I ended up junking the car before having to deal with whatever was causing the problem.
I assumed that the underlying problem would be fairly easy to diagnose, but it looks like it's gonna be more complicated than I thought, though hopefully cheaper to fix than replacing the master cylinder.
Well, what does the brake fluid look like? Is it dark? When was the last time you flushed the brakes? Do you ever use your parking brake? I've had mine begin to seize up on me causing difficulty with the pedal.
I don't know your budget, but O'Reilly has reman'd Denso units for around $30. I've had good luck with those. In fact, I have one on my '86 right now.
I'd definitely just replace the master cylinder and flush the fluid. Try flushing first since that's the most simple procedure.
I guess you could describe it as "pushing back". I think I'll flush the brake fluid first and see what happens, but somehow I doubt that alone is gonna help much.
I gotta do some research on how to do this properly, since I don't want to take any chances of causing the brakes to fail due to a bubble in the brake lines or something similar.
Found this thread:
https://www.yotatech.com/forums/f2/o...g-done-149414/
Found this thread:
I'm still not sure i would describe what the brake pedal is doing as "pushing back". Normally when I press the brake pedal, it travels a couple of inches then I feel increasing resistance.
But when it acts up these days, there is almost no travel at all, and it's it impossible to push the pedal more than an inch or so. It stops the truck OK, but it's not exactly confidence-inspiring. Then it goes back to normal after a few stops.
It feel like it's pushing back, but I think that's because the pedal is so hard to press at all.
Sounds like the same pedal you would have with the engine off. No power brakes.
With the engine off, push and hold the brake pedal down. Now start the truck. the pedal should sink some as the power brake booster starts to assist your effort on the pedal. It probably doesn't. Probably a leaky diaphram inside the booster. The check valve is a way easier fix. Pull it out of the booster with the engine running and make sure you've got lots of vacuum there. You can also spray some carb cleaner around the hose-check valve-booster area to check for vacuum leaks.
OK, so i bought a one man brake bleeding kit and bled all four brakes. I pumped out about 18 ounces of extremely brown brake fluid and replaced it with fresh dot 3 Prestone fluid. Took me about an hour and several wet spots on the driveway.
Braking feels much more confidence-inspiring now, and brake pedal feels normal all the time (so far anyway).
So evidently, my brake fluid needed changing after 200k miles. Go figure. I still have enough fluid left to change out the fluid in the clutch too. I assume that's pretty easy?
done exactly the same way. same nipple also.
Honestly if you're brakes are doing something 'funny' you never just 'ignore' it.
If you hit someone because you 'ignored' failing brakes you'd be in a heep of trouble and guilt.
On the other hand, good job at working brakes (for now)
Yeah well, I can laugh about it now.
And you have to figure that there's always a certain amount of risk in making things worse by trying to fix them. So I was sort of factoring that in, as well as assuming that I could probably sue Toyota if anything too bloody happened out on the road.
)Anyway, peckinpah.......
Using the same method as flushing the brakes, find the clutch slave cylinder on the passenger side of the tranny bellhousing. You'll see a nipple (there's that word again.....
) like the brake cylinders and calipers have on it. Have someone pump the clutch, crack the bleeder, allow the fluid and any air to expel, and keep repeating until the fluid comes clear and air free. Unless you have no one to help you, you really don't need the kit for this. It goes rather quickly. Hell.....since I've never had a bleeder kit, I don't know if it will even work for the clutch. Still.....happy nippling.
My current situation is pretty similar. My brakes used to have these sporadic feeling when pressing on it; sometimes its a one press motion other times you've had to pump it a few times, and sometimes it just sinks to the floor... kinda nuts lol
So all i did was change the master cylinder and did the brake flush. The old brake fluid was black as ink absolutely disgusting. Now it doesn't have the sporadic behavior.
However, when im driving and press on the brake.. it goes down about 2-3 inches and stays hard. I often downshift to help compensate for slowing the truck down.
Do you think I should replace the brake booster???
Here's a gnarly story btw: I used to own an 89 single cab 4x4 22re manual. and one time a car suddenly pulls out in front of me while i was traveling like 45-50 mph in 5th gear. I had little to no time to down shift so I relied on my brakes. When I pressed on it, I heard a popping sound almost like a super loud clap and the pedal went straight to the floor. Luckily, I was able to swerve around the vehicles and prevented a rear end accident. When I went home all of my fluid had leaked out and I noticed that my LPV (Lower Proportioning Valve) which is located on the passenger side back frame was destroyed. That was the day I realized how important brakes are. Had to redo most of the lines as there were multiple cracks in them as well. Flaring brake lines aren't fun lol.
Any aircraft maintennance company will be more than happy to hire a skilled hydraulic mechanic. At a good pay rate. So learn to flare brake lines well, and it's a skill that will follow you your entire life. And support you very well. I know it sounds like a small thing to know, but aircraft need good hydraulic mechanics, and flaring hyd lines to mate two lines is a skill few have.
Just my .02 cents worth. I know the aircraft industry. I grew up in it, and worked in it my entire life. Granted, I'm Radar tech, but I can look and see what's going on around me in the industry.
Have fun flaring!
Pat☺
Replace your rubber lines,all 3. Never seen a bad Toyota Booster. Also check the portioning valve in the rear make sure it's not freezing up and causing a sporadic issue. Sounds like you covered the rest.
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
