Brake confusion
If you didn't do anything to extend that LSPV (yes load sensing....) Then it thinks your "unloaded" and it relieves ALOT of the rear brake line pressure. It's probably why you have very little brake. Try unbolting the bracket and zipping the rod all the way up temporarily and see if your braking gets any better.
Personally I wouldn't leave it that way though. Some people have cut that rod and made an adjustable turn buckle for them to adjust the pressure to their liking. Problem with leaving it all the way up is if your in snow/ice the rear will lockup real easy.
If you don't have a dual booster then the MC is only gonna be like a 7/8's no need to measure it. This is assuming noone upgraded just the MC.
is there a way to adjust the LSPV to make the front stop locking? my front right brake will randomly lock sometimes and i think it has to do with the LSPV. it did it alot so i unbolted the rod and zip tied it to my metal brake line thats connected to the axle and it hasn't locked up for about two months now. but it locked up again today. so would making a bracket that raised it a couple inches help the front brake from locking? thanks
The LSPV only controls rear brake pressure not front pressure. My guess the reason why that worked is because now your not pressing the pedal to the floor as much when you had a lower pressure in the rear. Now that you have been running full pressure in the rear and your shoes have been wearing out quicker your back to square one and pushing on the pedal more.
#25
britishdudes2dr
Jul 25, 2015 06:47 AM
CanRunner
Jul 20, 2015 01:29 PM
