Block antifreeze drain plugs 22re
Ride 1993 toy extracab 4x4 22re
Does anyone have pics of where the block antifreeze drain plugs are? And any insight of how to drain the entire system easily?
I have the high 1900 rpm idle and would like the clean the system to make sure nothing is plugged before tackling something else.
Thanks
Thanks
I removed some heater and engine hoses and used a shop vac exhaust air to flush out the engine. Seemed to work. The engine drain is nearly impossible to access and even then it is nearly impossible to remove.
Good luck.
Good luck.
Sep 4, 2015 09:27 AM
