I was unbolting my front swaybar to replace the bushing and the nut welded on the inside of the frame broke loose of its weld so that it is free spinning. I'll cut out the bolt, but I have nothing to attach a replacement bolt too to secure the swaybar bushing mount.
Is a nutsert appropriate? The bolt takes force when the sway bar is twisted (i.e. suspension flexed).
I'm not an expert but I might try and drill the hole out a little larger. If there's a frame plug near you might be able to get a larger diameter nut in there with pliers or a magnet. Thread a bolt through the hole and into the nut to hold it. Weld the new nut in from below.
Ihave had this happen on my Hondas before. I typically just cut a hole out nearby and attach a wrench too the broken nut to remove the bolt. Then just leave the hole open for future use.
Are there any access holes? I would run a bit thru the hole to clean it up. Then with a new nut, granted there's an access hole, attach a long solid rod or tab to the nut. Voila. Bolt it up.
Can you fish a carriage bolt in there and use a nut on the other side? You'd have to die grind a square in the frame to keep the carriage bolt from turning.
I had a similar issue happen in my truck (captive nut in crossmember that holds a skid plate on). What I did was drill the hole out slightly larger, then burn a weld nut in. They are available in a variety of sizes and threads from mcmaster carr
installed a rivnut. worked well. used a combination of thread locker, antiseize, an appropriately-sized nut, bolt and some washers. the thread locker keeps the rivnut from moving on the bolt, the antiseize and washers keep the nut as friction-free as possible. the nut travels down the bolt towards the rivnut and collapses it. used a rattle gun to break the thread locker and extract the bolt.
I'd say "meh" to the rivnut solution. But I know a lot of folks don't have access to a welder. The correct (or more correct, if you want) is to remove and replace what was there from the factory. I personally measure it out first, or make a template, to make sure I get the new nut in the correct position. Then using a slightly larger hole saw (large enough to drop out the old nut) I'll cut out the entire offending piece. Then I make a plug that exact size (same hole saw on new metal plate), then I'll weld a new nut to the new metal plate. Then I'll take that assembly and weld it into the hole I cut out of the frame. Welding over your head is fun!
If you do have to use a rivnut, make sure it's the appropriate one. Meaning, made out of the correct material. Steel rivnut to steel, aluminum to aluminum, stainless to stainless, and so on. You don't want to stick an aluminum rivnut into steel. Not only is it not strong, but the dissimilar metals can react with each other and cause oxidation/corrosion.
