Best way to test AFM
Old Jun 2, 2011 | 10:58 AM
swerks's Avatar
I know you can test with a multi meter but is there any thing else that can be done to make sure its working correctly ?
Old Jun 9, 2011 | 09:49 AM
swerks's Avatar
Old Jun 9, 2011 | 01:35 PM
sb5walker's Avatar
Resistance measurements will pretty much establish whether the meter is good, but to test the wiring & make sure the signal is getting to the ecu, you can measure the voltage at the ecu terminals (with ignition on). See the MFI System - Troubleshooting chapter for specs. Use backprobe adapters on your multimeter probes if you have them; otherwise stick needles into the connectors and hold probes against those.
MadMax48
Mar 3, 2020 10:33 AM
sanctfy
Sep 13, 2015 06:33 PM
some drunk guy
Sep 4, 2015 11:55 PM
