Best Flywheel and clutch set-up(bang for your buck)?
Old Jan 12, 2012 | 02:50 PM
CitrusTheDragon's Avatar
I have done some searching over the last few days and I have found that a 22ret set-up will fit a 22re. But does anyone know of a light, maybe race style set-up that can be bought. I read somewhere, and now can't find it that maybe a mitsubishi set-up might work. Anyone have some input?
Old Jan 12, 2012 | 04:04 PM
Philbert's Avatar
I got a clutch kit from Marlin for $149, and a SACHS flywheel from the local auto store for $53 (would be $75 to resurface the one I had, which is in ok shape.
No idea on the aftermarket stuff though...this was my first flywheel job and DANG that thing is heavy!!
Old Jan 12, 2012 | 04:08 PM
that thing weights like 30 or 40 pounds
Old Jan 12, 2012 | 04:09 PM
ttrmike's Avatar
I would stick with a stock weight flywheel, but LCE does make lightweight versions, though they're not cheap...
http://www.lceperformance.com/Search...x=0&Search.y=0
Old Jan 12, 2012 | 04:20 PM
wow those are pricey
Old Jan 12, 2012 | 04:48 PM
any upside to running a 22ret setup over a 22re
Old Jan 12, 2012 | 11:27 PM
wyoming9's Avatar
Red face
With the 22RETC clutch you do need to get the proper flywheel as the Turbo one has the pins in a different place.
I found it out the hard way wrong clutch in the right box trying to get the turbo clutch on a stock fly wheel just about drove me crazy.
I have had good luck with LUK clutches Although I do Have a Aisin here to try on the next one
Old Jan 13, 2012 | 01:06 AM
drew303's Avatar
I've been running marlin crawlers clutches for years now, i use the 1600lb version currently, works for me.
as for flywheels, i get em from oreilly's, theyre like $80 new... just a word of caution, i installed a new flywheel YEARS ago and there was a cast imperfection on the engine side of the wheel that was hitting the bolt heads of the dust plate to the bellhousing. First start up of the motor it sounds like the thing is disentegrating..3 transmission removals later, the noise went away... (omg the work.... what a nightmare)
it wasnt until i replaced the clutch again years later i actually discovered what caused the ruckess... it was only coincidence the noise went away after the third tranny removal just because the flywheel had finally ate the bolt heads down to where they didnt contact anymore, lol
Anyway, ever since that experience, after i install a flyhweel/clutch i hand spin the motor to check for clearance issues
Old Jan 13, 2012 | 07:32 AM
dntsdad's Avatar
Marlin has flywheels are well
Old Jan 13, 2012 | 07:58 AM
irab88's Avatar
i'll be running the ceramic clutch on the stock flywheel. i'm installing it next week, so i'll let you all know how it goes.
Old Jan 13, 2012 | 08:07 AM
waskillywabbit's Avatar
I use Aisin. Resurface or buy new OEM. Going into a tranny multiple times because of cheap/wrong parts sucks. Do it once, right.
Old Jan 13, 2012 | 03:40 PM
suncomb1's Avatar
Stock flywheel, pilot bearing and a Centerforce II clutch assembly. The clutch system is almost bullet proof and easy on the leg.
Old Jan 13, 2012 | 05:04 PM
peow130's Avatar
Turn flywheel on a brake lathe, shave off 10 lbs and you've got a rev monster
That being said, i wouldnt do that.
Old Jan 13, 2012 | 06:37 PM
scary but I have heard of people doing that,
Old Jan 14, 2012 | 07:52 PM
Is the flywheel on the 22re and 22ret the same??? Napa and O'Riellys has the same part number for both flywheels
Old Jan 15, 2012 | 04:17 AM
sechott's Avatar
I was thinking about a ceramic clutch when time time comes to replace mine. I decided against it when I read they are not street friendly. If you get one let us know how you like it.
Old Jan 15, 2012 | 05:35 AM
abecedarian's Avatar
I don't see any need for a lightened flywheel if you're using your truck as a truck. The weight of the flywheel adds "torque", so to speak, when you're shifting gears. It may take a little longer to rev up, but it won't rev down as quickly.
The last thing you want is a twitchy clutch that requires you to be precise with your clutch. If you are doing something like racing it, then yeah a ligher flywheel will let you rev up more quickly but you'll have to slip the clutch more.
The flywheel is a "conservation of momentum" thing meaning you don't have to slip the clutch as much to get going.
Old Jan 15, 2012 | 02:27 PM
Since you bring up ceramic clutch, anybody know the upside? downside?
Old Jan 15, 2012 | 04:00 PM
irab88's Avatar
cools faster, heats up slower, doesn't stink when "slipping", more clamping force per sq-in
Old Jan 15, 2012 | 04:06 PM
sechott's Avatar
I never experienced a ceramic clutch. So this is basically what I have read, they are jerky because they will not slip like organic material. They can hot spot the flywheel, this maybe from using lighter weight FW but not specified. They are noisy and chirp. Starting off uphill is a lot trickier. Only benefits seems to be for racing purposes.
