best choice for hd alternator wire terminals
Old Sep 14, 2009 | 05:56 PM
LITLRED's Avatar
Originally Posted by Jay351
you can do it man. This stuff is really easy.
Just cut off the old connector, slip on the new one so its almost completly on, then just heat it up and put your solder into the connector. It will melt instantly and you will be done!
Then slip over some shrink wrap and your done
Avoid a common mistake (I've made it many times) and be sure to slide on the shrink tubing before putting the terminal on. I used to use a hair dryer on the shrink tubing and it took forever, plus didn't score any points with my wife.
Now I use a match or lighter...very simple and quick.
Old Sep 14, 2009 | 09:27 PM
89934runr's Avatar
connector
Don't waste your time with the Napa / Calterm terminals and such- these are what the factory (GM) uses. There have the properly sized holes & retention tabs, and are very easy to solder on (they are tin plated). You can use common pliers to fold the wire retention tabs over, then solder it for a never-let-go connection.
Search around on Mouser's site & you'll find everything you need, at good prices to boot. I buy these in bulk all the time. They get everything to you quickly as well.
http://www.mouser.com/ProductDetail/...qxp1G18A%3d%3d
80Truck
Oct 12, 2025 07:25 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
TDonkey
Jul 26, 2015 10:14 AM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
