Best Brand ATF for an Older, High Mileage Transmission
Old Aug 25, 2015 | 11:12 AM
chuckross1957's Avatar
Looking for a good ATF to use in my 86 truck with the A43D transmission, originally listed for Dex II. I see there are some concerns with the viton rubber seals in older transmissions and Dex VI. I am looking at Valvoline Maxlife and Mobil Delvac. Anyone using one of these in an older Toyota transmission.
Old Aug 27, 2015 | 10:54 PM
maco35's Avatar
I only use dexron VI on mine, (220,000) miles.
Old Aug 28, 2015 | 04:48 AM
AKHeathen's Avatar
why the heck are you guys switching to a synthetic fluid in an aged automatic? there are so many things that can go wrong with that. yes, it is a better fluid, but it's properties are different and can effect valve pressures and not to mention, incompatability with conventional atf can dry out and kill the seals before they take the new fluid. aside from that, the clutches do the same. it leads to tar/sludge in whom knows where. if you are going to make the switch from conventional to synthetic, it's best done when the trans is rebuilt. there is hardly any difference in brands of atf, just cheap and better. biggest thing is keep it clean.
Old Aug 28, 2015 | 05:39 AM
maco35's Avatar
Owners manual says to use Dexron II ATF wich is not available anymore, so dexron IV is just an updated new version of the original dexron from the 80's but is just conventional ATF not synthetic ATF, and my transmission is running like a champ.
Old Aug 28, 2015 | 05:47 AM
AKHeathen's Avatar
dextron IV is fine, but you said dextron VI which is synthetic
Old Aug 28, 2015 | 03:12 PM
I've heard some say if you are converting over to a synthetic, do a gradual conversion. Also heard the Maxlife isn't a true synthetic, but a highly refined conventional ATF.
Old Sep 7, 2015 | 09:34 AM
desert_vet's Avatar
Use what is factory comaptible & I would also add some Lucas ATF treatment. It is like there oil treatment a little thick & very red. Hope that helps you. As always take the advice of others with a grain of salt. Some bad, some good. Just use your own judgement of it.
88sasturbotoy
Jan 30, 2026 01:57 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
PureTacoma_Tundra
PureTacoma_Tundra
Jul 23, 2015 11:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
