Basic High Quality Suspension
Old May 8, 2008 | 09:10 PM
chilly_bill's Avatar
Any recommendations on the best quality suspension for a '91 2WD pickup w/ a 22RE. I do not need to lift at all. I'm just spoiled on my other vehicles and would love to have the truck ride and handle as best as possible.
Old May 8, 2008 | 09:29 PM
abecedarian's Avatar
What type of handling do you mean, off or on road?
Fabtech has a decent kit but is a bit stiff if you crank it for the 2.5" lift it advertises. Total Chaos has (what I hear) an almost bullet-proof long travel kit also but is pricey. I've heard mixed about Downey's kit.
I've got the Fabtech on my '91 2wd/22re/auto and it actually rides like a truck now- subtle bumps are responded to a bit too firmly but whoops are sucked up and the truck comes up without bouncing.
Old May 8, 2008 | 09:33 PM
Jay351's Avatar
Sounds like you want it to handle better on road. Perhaps the few 2wd boys will chime in here...
Old May 9, 2008 | 07:48 PM
Well, no other '2wd chimers' for on-road so...
on road:
front- stock torsion bars. urethane control arm and sway bar bushings. shorten the sway arm end links 1" and use urethane bushings. relax the torsion bars so you have 1/2" spacing on the upper bump stops (compression) and install urethane compression bushings on the shocks to ramp up 'jounce'. Set the alignment to 1/16 toe-in, camber to -.5 degree (top of wheel in), caster at where it sits. urethane bushings on the strut rods.
Sorry- here's my edit:
front- total chaos long travel suspension set up with everything else as I mentioned above except for 1" spacing on the compression stop.
rear- torque-reactive limited slip differential (torsen type), stock springs with load and last leaf removed and 2" lift shackles, urethane bushings on the spring eyes, 28mm anti-sway bar with urethane bushings.
just kidding, I was making that up. But I bet it'd be something to play with.
Old May 11, 2008 | 05:35 AM
dirtoyboy's Avatar
Replace with NEW stock suspension...sounds like thats what you are looking for...just find a pair of junkyard springs that are in better shape than yours or just slap an add a leaf on em
Old May 11, 2008 | 10:00 AM
Hmm. Thanks for the input. Yea, I'd be using it 95% on-road and am just looking for the best handling 'round town and through the twisty mountain roads.
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Aug 30, 2015 08:55 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
4x4-runner
Aug 2, 2015 09:24 AM
coffey50
Jul 28, 2015 10:55 AM
