bad rings or bad valve stem gasket?
Old Nov 13, 2007 | 04:40 PM
co4rnr's Avatar
Originally Posted by Turbo4Runner
I don't know what stock 22RE's do at sea level but 140psi sounds about right for 1 mile+ above sea level. Altitude makes a huge difference.
Here's a post on another forum that shows the math:
http://www.eng-tips.com/viewthread.c...169417&page=15
It basically shows that a reading of 160psi @ sea level is about 113psi @ 7800 feet.
That's where turbo's come in handy..
That is an interesting article. However I don't think it is quite accurate. Lets just assume that since I live at 6,000 feet my compression should be about 65% less than at sea level. My compression test proved to be 140 PSI and if the calculation of 65% less is correct my sea level compression should be at 215PSI. The way I got this is to divide 140 by .65.
Old Nov 13, 2007 | 07:51 PM
dcg9381's Avatar
Originally Posted by co4rnr
Hmmm, this makes me think. When the engine was rebuilt the cyliner walls were measured and found to be within tollerance. Stock piston size was used. The cylinder walls were not bored out. they were honed out.
Did you measure them or a machine shop? IE - confident they were measured correctly?
Rings correctly installed and gapped?
Once a cylinder has been bored, it's honed to a final size that is correct for piston to wall clearance. *Most* 22R motors, by the type they need a rebuild, will no longer be in cylinder to wall specs. The bores tend to not wear the same across the bore.
Still, I'd do a leak down test to confirm rings... Cam profile can cause differences in compression...
The miss below 1800 is interesting also.. Try pulling one cylinder at a time, see if you get an RPM drop. You're looking for the cylinder that doesn't cause a drop - that's the one with the miss...
Old Nov 15, 2007 | 05:29 PM
co4rnr's Avatar
update
I did not get a chance to do a leak down test. However, I did do another compresion test and found out that when I added a teaspoon of oil the readings went from 140 to 150. Not a significant jump, but does that mean that the rings are indead bad?
Also all the spark plugs where nice and black and sooty. Is this from oil getting into the combution chamber?
Old Nov 15, 2007 | 08:21 PM
longhungsilver's Avatar
pictures of the plugs would help
Old Nov 15, 2007 | 08:31 PM
  #25
BC_4runner's Avatar
if its consuming oil then the rings are bad
it shouldnt take that long for the rings to seat. My rebuild stopped using oil after 400 miles
Also if the plug are black and sooty that means its running rich. If the plugs are black and wet, then its consuming oil
Old Nov 16, 2007 | 10:33 AM
  #26
co4rnr's Avatar
Running Rich?
The plugs were all dry and black. There was a little oil by the threads of the plugs, but the plug tips were dry. How do I get it to stop running rich?
Old Nov 16, 2007 | 07:59 PM
  #27
BC_4runner's Avatar
If its a "sooty black" then its running rich but if its just a dry black and it hasnt been run for awhile then its oil.Try pulling the plugs right after running it if they are wet then you know for sure
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
sojourner567
Jul 16, 2015 08:52 PM
87blyota
Jul 10, 2015 04:31 AM
