bad miss
Old Jan 1, 2008 | 06:55 PM
doubledizzle's Avatar
Exclamation bad miss
ok need major help.....22re not doin to well, went for a swim the other night and it stalled as soon as i hit the water which i was expecting it to..but once i got all the water outta everything it runs but now its like it has a miss backfires all the time and you can feel it....pulled the plugs and number 4 was burnt rich so i changed them and cap/rotor still same miss and still foulin up number 4?? some one please helllpppp!!!!......also had to get a new idle control valve (old one has been shot for awhile) and now it wont make up its mind about idle it will run fine sumtimes and then sometime when i come to a stop it just stalls out ive adjusted the air fuel mixture many times and just cant get the happy spot so if any knowlege pleasee help me! thanx so much guys
Old Jan 1, 2008 | 08:04 PM
toytech76's Avatar
Did you suck any water in the eng? Maybe you bent a rod if you did. Make sure all water is out of anything electronic
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
TDonkey
Jul 26, 2015 10:14 AM
