Bad alternator or something else?
Old Oct 11, 2015 | 08:02 PM
jfoltz's Avatar
I have a 91 pickup 22re and when driving at night with the lights and heat on my voltage drops a little under half way and my radio will cut off, the headlights and dash lights dim and the heat barely blows warm air but the truck will still run but once I turn it off I have to wait several hours/next morning for it to start back up unless I jump it. Are these signs of a dying alternator or bad voltage regulator or something else?
Old Oct 12, 2015 | 12:11 AM
wyoming9's Avatar
Red face
Time to get a Multi Meter get some real voltage numbers
It could be any number of things
Charging system problems need to be looked at one step at a time.
Corroded or loose battery terminals
Corroded or worn connections in the battery cables. Bad grounds will cause all sorts of issues
Even a loose belt
Don`t blame a bad alternator till every thing else is checked out.
montanatruck
Feb 26, 2017 07:07 AM
ViperTT
Aug 14, 2015 05:27 AM
Ryan_a118
Aug 12, 2015 12:57 PM
rustym
Aug 7, 2015 10:39 AM
jake_v
Jul 22, 2015 03:17 PM
