Auto trans
Old Dec 9, 2015 | 11:37 AM
Bword89's Avatar
Auto trans
So I have started having trouble with the way my truck shifts it will go through 1-2 quick then I'm lucky if it will shift to third but if it does it very rarely shifts to OD I was reading a post on here about a lockdown cable I believe is what it's called and I adjusted it but it's starting to move the sheath not the cable what's y'all's input on this
Old Dec 9, 2015 | 11:56 AM
scope103's Avatar
That's not it.
There is no "lockdown" cable. Much older (all hydraulic) transmissions had a "kickdown" cable which would delay upshifts when the throttle was depressed. While I don't know what vehicle you have (is it a Toyota? Of any kind?), you probably have a "throttle cable" which ONLY affects how "hard" the transmission shifts. The shift points themselves are all controlled by the computer.
Have you run the transmission diagnostics? You'll help yourself a lot if you tell us the vehicle you are driving AND the transmission you have (look on the door pillar).
Old Dec 9, 2015 | 12:44 PM
Bword89's Avatar
It's an 87 xtra cab 4x4 auto trans
Blillyyota
7
Nov 29, 2015 08:07 PM
SubiKing
Nov 25, 2015 12:50 PM
Jonny246
Nov 12, 2015 03:28 PM
rugerm44
Nov 12, 2015 02:20 PM
Jethro540i
Nov 12, 2015 06:09 AM
