auto hubs to manual.
They are all over the place; it's a REALLY easy swap. Here's some I got with a 10-second search:
https://www.yotatech.com/forums/f116...aisin+hub+swap
*EDITED* to correct link
hahahaha... TNR, searches are linked to your user name... what we see is a box that says that your search returned no results...
heres one that i did...
https://www.yotatech.com/forums/f116...ild-up-158644/
theres also a couple others out there... (c'mon trav and scoobie, i know you wanna post your links too!
Honestly... One of the easiest mods there is..... It IS as easy as it looks. Just remember to leave the bolts on when u beat on the add flange, or the cone washers could end up on the otherside of ur garage.
Quick question - the guy I'm helping just got a used set of manual hubs, but without the bolts and washers. Does anybody know the proper bolt size so we can pick up a set? Thanks!
Yes - I did search, and found plenty on the conversion process. Nothing to it. Didn't find info on the bolts themselves, though.
FS[SouthEast]: Aisin factory hubs, cleaned and lubed
carlspeed
Aug 23, 2015 02:59 PM
