Any issue w/ swapping rear axle/hub/brakes from passgener to driver side?
Old Mar 29, 2010 | 05:12 AM
Schnit's Avatar
Wondering if there's an issue running a rear axle assembly (hub, bearing, brakes) that was on the passenger side of the truck for quite some time, to the driver's side.
Had a stud break off when I pulled the axles and this is an option. Otherwise if it would cause issues turning the opposite direction that everything has turned for the past decade I do know of a local yard that has one.
Old Mar 29, 2010 | 07:56 PM
tc's Avatar
tc
Yes - the brakes have sides and the ebrake attachment won't be in the right place.
Old Mar 29, 2010 | 08:11 PM
Tofer's Avatar
Sponsor
x2 on what tc said
Old Mar 29, 2010 | 08:15 PM
RMA's Avatar
RMA
you could use the old brake stuff ..
Old Mar 29, 2010 | 08:17 PM
tc's Avatar
tc
Not really - you'd have to press off the bearing, swap out the brake backing plate and all that jazz, then press it back together... for all that, just rebuild the proper one.
Old Mar 29, 2010 | 08:23 PM
RMA's Avatar
RMA
oh yea the lever is on the backing plate ..
primordialbeast117
Dec 19, 2015 12:23 PM
zanzabar0
Oct 11, 2015 02:56 AM
scott90
Oct 4, 2015 09:21 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
