anti freeze just leaked out all onto the ground
Old Oct 1, 2008 | 10:40 AM
John911's Avatar
I just came home from the park, my truck was running perfect, anyways I pull in to my driveway with the window rolled down and I start hearing a really weird noise. I put it in park, pop the hood and get out to inspect what it could be. Anyways I see all my anti-freeze from the radiator spilling onto the ground. I mean ALL of it came out. Then it started smoking like crazy so i had to get the house and squirt it all over the radiator.
Anyways, the leak is from the bottom i know that for sure. So what could have caused this to happen? I have no experience whatsoever on this stuff so bare with me.
Also my truck is a 1988 2WD toyota pickup 22RE.
Thanks,
John
Old Oct 1, 2008 | 10:41 AM
ozziesironmanoffroad's Avatar
prob busted a hole in your lower radiator hose
Old Oct 1, 2008 | 10:54 AM
mmcpeck's Avatar
Yeah I'd say you blew a hose. In the future, not a good idea to blast a hot engine or anything for that matter, with cold hose water. You could make things a lot worse.
Old Oct 1, 2008 | 10:56 AM
John911's Avatar
I didnt blast the engine, what I did was when the hood was closed I squirted the grill with water because smoke was coming out and that immediently stopped it.
Also another question, is a blown hose the only cause of this? Could it have something to do with the thermostat?
Tell me what I should replace and ill replace it doesnt matter how much the cost is, i just dont want this happening again in the future.
Old Oct 1, 2008 | 11:05 AM
904_runner's Avatar
Might as well replace the thermostat if you haven't done it in a long time.
just replace the hose, hopefully it will be fine.
Hoses get old probably why it ruptured
Old Oct 1, 2008 | 11:06 AM
mt_goat's Avatar
Calm down...fill the radiator up with some water and look to see where its leaking from.
Old Oct 1, 2008 | 11:07 AM
tampabayota's Avatar
problem
dont take this the wrong way but untill you actully look it is hard to answer your question. It could be the hose ,it could be a seam leak, could be the tstat, could be the coolant faireys
Old Oct 1, 2008 | 11:15 AM
904_runner's Avatar
oops! thought i read that teh hose was busted
X2 check where it is leaking from. then go from there
Old Oct 1, 2008 | 11:36 AM
mt_goat's Avatar
Funny....my first thought was a stray round from a drive-by shooting got his radiator.
Old Oct 1, 2008 | 12:18 PM
MMA_Alex's Avatar
x2 for the coolant ferries
Old Oct 1, 2008 | 12:25 PM
mudhoney's Avatar
haha..whooo thats great hehe.........ya could be anythin...........probably a leak on the system but could be an overheating by-product if you noticed the temp. when it happened idk.
Old Oct 1, 2008 | 01:04 PM
1styota4X4's Avatar
I think when all the coolant rushed out it was proven to be a leak in the system
Old Oct 1, 2008 | 01:30 PM
Alex 400's Avatar
question. in most american water pumps, when the bearing starts to go in the water pump the seal blows out the back because of heat. is this the same for our yotas'?
Old Oct 1, 2008 | 01:55 PM
NwRunner's Avatar
Last time i tried squirting my truck with the house i broke my grill
Old Oct 1, 2008 | 04:24 PM
Matt16's Avatar
Blamalam
Mar 12, 2022 07:34 AM
Tacoma1313
Aug 17, 2015 05:44 PM
Sr5crawler
Jul 31, 2015 12:32 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Jonny246
Jul 12, 2015 04:51 AM
