another emp guage
Old Jun 20, 2006 | 10:55 AM
hirsche23's Avatar
another temp guage
While I have the head off my engine I want to fix the crazy temp gauge,the stock one doesn't seem to be 100% accurate so I want to put in an aftermarket one so, will I run into problems if the stock one is unplugged?Can I leave it as is and run a new sending unit to the block drain on the drivers side and have two working guages? I like to know how hot my unit is running so 2 gauges would suit me fine,has anyone done this?It is a 89 22re
Old Jun 20, 2006 | 03:28 PM
LOCKnGO's Avatar
I would think that if the threads match the aftermarket sender it would work fine. thats how I did on my old chuvrolet 350 block.
You could also get a piece of stainless pipe and weld a bung on for the sender, then cut/couple(sp) the hose going into the rad
I had that set up on my old Volvo w/ 302 conversion and it seemed to work pretty well.
wafoogalla
Nov 2, 2016 11:02 AM
jacked_72
Sep 14, 2015 03:31 PM
izzmee
Aug 17, 2015 10:20 AM
shisha1999
Jul 13, 2015 11:09 PM
Weasy2k
Jun 23, 2003 07:08 PM
