another of the 10000 torsion bar threads
Old Mar 28, 2008 | 11:12 PM
Beaniam's Avatar
however this one isn't about the top nut spinning. The little bit I am able to turn the adjuster bolt I can see the top nut isn't spinning however the half moon spacer on the bottom is. This makes it nearly impossible to turn, I can only go about half a turn in each direction. I'm figuring the bolt is gonna break and be siezed in that spacer. I'm already ordering a set of bolts and nuts but can you get that half moon spacer as well?
Old Mar 29, 2008 | 05:03 AM
Brenjen's Avatar
Well, if you had read my thread in general vehicle related topics you'd have seen my recent problem with this very same thing. Just turn it anyway! The bolt & washer will slam down as it aligns with the saddle again but just keep turning it.
Here is what I did; I PB Blasted it for about two weeks once a day prior to trying to move them (spray inside the hole too), I used a wire brush to clean the crud off the top of the bolt & once the bolt was clean above the nut I slathered a thick layer of anti-seize compound on it & then I reached the brush into the hole & slathered as much of the bolt as I could reach in there as well. The crescent shaped washer spun, snapping & squealing the entire time until I tightened back up a little. I found it only stuck like that on the way down but not on the way back up. After a few turns up & down trying to adjust it; it will now turn without the washer moving. It's still a little stiff on that side (drivers side) but much improved. The passenger side never gave me a seconds trouble & turned easily.
Old Mar 29, 2008 | 04:43 PM
ewong's Avatar
I think the infamous torsion bar adjuster site (Chris Geiger's old page) has the part numbers.
Yes - you can get the half moon from the dealer
andrewtexas123
Jul 6, 2016 01:49 AM
Steven.m.paulk
Aug 16, 2015 04:52 AM
mavenator
Aug 13, 2015 01:12 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
