Aisin Front Manual Hubs in bits.... Help
Old Oct 25, 2009 | 12:18 AM
discostuee's Avatar
Ive picked up some front wheel locking hubs for me 91 IFS 4runner to change to manual. I got the pair of hubs for $25 as they are in bits. Can someone tell me where some info are to A) check i have all the bits B) work out how to put them back together.
Thanks in advance.
Old Oct 25, 2009 | 12:38 AM
drew303's Avatar
Check the links to the FSM's here... Links are in a sticky.
Aisin hubs are pretty simple tho, and strong.. easy to work with in other words.
theres a 93 FSM that will have a diagram of the parts.
Old Oct 25, 2009 | 01:04 AM
wyoming9's Avatar
Red face
Just remember if you are swapping from auto to manual hubs you need the extra hardware from the manual hubs to hold the wheel bearing .
Otherwise they do tend to come loose
This would be the thrust washer the 2 nuts and the lock washer for each side. And of course never seize the cone washers
Good luck
Old Oct 25, 2009 | 05:28 AM
waskillywabbit's Avatar
https://www.yotatech.com/forums/f129...sembly-186374/
Old Oct 25, 2009 | 05:49 AM
nv4runner's Avatar
Going from ADD to Manual is a breeze and you should only need the 2 washers per side. I have mine setup and ready to go. All I'm waiting for is my instructor...he wants to use my manual hubs as a group demo in class. Doesn't bother me though cause we're all going to check my wheel bearings while its apart.
Old Oct 25, 2009 | 06:32 AM
Good luck
He has ADD, not AUTO.
AUTO hubs were on Toyota 4x4s came between 1984 and 1989
ADD to MANUAL you only need the Aisin Manual hubs for 86-95 (IFS) and the associated parts and a set of gaskets. You don't need any washers??
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
1996Taco
Jul 20, 2015 12:02 AM
ItsJustD
Jul 7, 2015 07:49 AM
