Air/fuel ratio rich indicator
Old Apr 12, 2010 | 09:22 AM
kyshooter's Avatar
I got a 26 code off jumper e-1 te-1. I am assuming this is an O2 sensor but I also have a couple of exhaust leaks. Should i start with the exhaust leaks or the O2 sensors.
Old Apr 12, 2010 | 02:39 PM
Jay351's Avatar
If the exhaust leaks are before the o2 sensor then they will most likely be your problems. The o2 sensor will think the motor is running lean and will richen the mixture up. You can test the o2 sensor with a digital multi-meter.
Longbed 90
Oct 19, 2015 11:05 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Aaronmarston
Sep 22, 2015 09:39 PM
justdifferentials
Sep 5, 2015 06:52 PM
