Advantages/Disadvantages to setting idle speed and ignition timing differently
Old Sep 16, 2011 | 04:20 AM
Ohio4Runner's Avatar
Since my recent 3VZE HG repair, I have been playing around with the idle speed and ignition timing settings. It is quite easy to set it to factory 750-rpm, 10* BTDC, and for what I need, the performance is OK. However, I like the feel of the engine more when it is about 1000-rpm, 15* BTDC.
My question is, what are the pros and cons of doing so? Obviously it has a little more power at that setting. What do I risk regarding emissions, fuel economy, and long term engine damage? Are there other considerations? Should I just leave well enough alone at the factory settings?
Thanks for the insight, in advance (bad pun, sorry).
Old Sep 16, 2011 | 05:20 AM
MYTOYOTA's Avatar
Hard to say man, first off do you have any mods or is your engine stock? If it's all stock leave it at stock.
EDIT: nice punn
Old Sep 16, 2011 | 05:32 AM
No mods, just stock.
What might happen if I bump it up a bit on the stock engine?
Old Sep 17, 2011 | 03:35 AM
MaDkAtT44's Avatar
Usually best to leave it stock, but if u want to do it your gas millage will drop by 10% or so, i drive in alot of stop and go traffic, so i set my idle to 1000 just so i can creep easier. but that being said, you will not be able to pass emissions, you can damage your cat. over a long period of time, and will most likely cause your pilot bearing to wear out faster, may even damage auto trans too but i'm not sure as i have nvr done this to an automatic vehicle.
B. Graves
Jul 3, 2015 04:10 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
serenity03k64
Jun 27, 2015 07:59 AM
Mr.Black
Jun 21, 2015 10:17 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
