Advance Timing for Better MPGs?
Old Oct 17, 2023 | 10:00 AM
SoCalToyotas's Avatar
Originally Posted by pimacdaddy
Mine is set at 5degrees right now and it jumps to 11deg when E1 and TE1 unjumped. So I should try 8 degrees jumped ?
you should always set timing with the connector jumped as that tells the computer you are messing with the timing so it retards its timing advance all the way in this mode. Without the jumper it will vary the timing based on several factors
IIRC if you want power you advance the timing, if you want mpg you retard the timing
artemyk
Aug 2, 2019 01:20 PM
jason098
Jul 27, 2019 03:06 PM
Corey Barlow
Aug 1, 2012 07:59 PM
DH6twinotter
16
Apr 5, 2003 09:41 PM
AgRunner06
Feb 9, 2003 06:12 PM
