Abs Ecu
Old Feb 26, 2008 | 02:01 PM
jason191918's Avatar
Abs Ecu
My abs light has been on since I bought my truck. I diagnosed the ECU as the culprit. Got a new one through Toyota and installed it. Problem not solved. Do I have to program it or something?
Old Feb 26, 2008 | 02:18 PM
Elvota's Avatar
Do you mean you replaced the primary vehicle ECU?
What was your diagnosis process before replacement?
What codes did you have before, and what codes do you have now?
The ABS light is on steady, or blinking?
Old Feb 26, 2008 | 03:13 PM
I replaced the ABS ECU.
I followed the diagnosis process in my chilton's manual.
The only code I had was 1 blink than solid, indicating faulty ABS ECU. This is the same code that I get now.
The ABS light still blinks once then stays on solid.
Thanks for replying.
Old Mar 1, 2008 | 10:37 AM
anyone else?
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
JimiJams
Sep 28, 2015 06:14 PM
matt1833
Sep 16, 2015 07:11 AM
zz_denis
Sep 6, 2015 03:43 PM
