AAD wiring for my 5-speed swap
Old Oct 16, 2006 | 02:08 PM
Spinnbait's Avatar
ADD wiring for my 5-speed swap
The automatic is out and the manual is in. It all runs....72 hours after I began. This was one of the most enjoyable things that I have ever done, but I need to finish the wiring to make it right. I have wired the neutral start and backup lights, but I can't figure out which wires that I need to tap into for my ADD in the harness next to the tranny. I can't trace them from the automatic because I have tried so many other combinations that I cannot remember the stock setup. If anybody with a '95 auto runner knows what colors the wires are or how to wire it, please help. Thanks.
Old Oct 17, 2006 | 12:38 PM
Spinnbait's Avatar
anybody?
I really need to remedy this situation. My O/D light is also flashing which I think is due to picking the wrong wire. Please help.
Old Oct 18, 2006 | 06:09 PM
^VooDoo^'s Avatar
Why is the transfercase connector from your auto different from the manual transfercase you installed, Should be the same.
Old Oct 18, 2006 | 06:53 PM
Spinnbait's Avatar
different
The plug for the auto has three wires. It uses a triangular plug and routes to an in-line position sensor. The manual plug has two wires and does not use an in-line ratcheting shifter w/ position sensor. I need to know what terminals/ wire color that the three wires mate up to at the main plug next to the bellhousing.
Old Oct 18, 2006 | 07:14 PM
mt_goat's Avatar
I'd just put on manual hubs and permanently lock the ADD in 4WD.
Old Oct 18, 2006 | 07:17 PM
Spinnbait's Avatar
Dd
It's my DD and I would prefer the best of both worlds. I already have manual hubs. I know this can be done correctly. Thanks for everyone's help, thusfar.
Old Oct 19, 2006 | 08:39 AM
anthony1's Avatar
The auto transfer case actually coupled to the transmission. They even shared the fluid. The manual trans and t-case are seperated. When you swap the auto to manual, you swap the t-case also.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
88yodabasket
Jul 13, 2015 01:32 PM
toyota32
Jul 6, 2015 05:42 PM
