A340H Park/Neutral Switch Inter-Year Compatibilty
Old Aug 26, 2015 | 10:38 PM
Hugh_Mann's Avatar
I am in the process of replacing a dead A340H automatic transmission in my 1994 3VZE 4Runner. My donor transmission is from a 1992 3VZE 4Runner. Yesterday I discovered that the electrical connector for the park/neutral switch (pictured) is different. Apparently it changed for years 1994-1995.
Will I be able to swap the switch from my dead '94 transmission to the '92 unit without issue? I've searched the forums and haven't found an answer.
Thanks for your input!
Old Aug 26, 2015 | 11:18 PM
AKHeathen's Avatar
try it and see. if it lines up with the shaft slot and bolt hole in the same place while in park, i don't see why it wouldn't work.
Old Aug 27, 2015 | 11:07 AM
Hugh_Mann's Avatar
Yeah I'm thinking it will work too. I'll post my findings.
Old Aug 30, 2015 | 07:36 AM
Hugh_Mann's Avatar
So it turns out the switches are backward compatible. I had no problem fitting the '94 switch onto the '92. Everything else was identical.
Glad to have this on record for anyone else searching the forums for an answer!
Old Aug 31, 2015 | 04:02 AM
AKHeathen's Avatar
thank you for following up sir. i'm sure many will now find this even on a google search.
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
