A340H Pan Gasket question ?
Old Apr 15, 2011 | 03:30 PM
McKenna's Avatar
I purchased shift solenoids & a filter kit from Makco a few days back. A Corked gasket came with the Filter kit, would there be a downside to running the corked gasket or should I just run with Permatex "The Right Stuff". I've read a number of threads where RTV was the only thing used, I figured I'd ask before I take this up to the shop and swap out my solenoids and filter.
Old Apr 15, 2011 | 03:32 PM
scuba's Avatar
Yes. It'll leak.
Just use what the factory used when they assembled the thing, RTV.
Old Apr 15, 2011 | 03:49 PM
James Woods's Avatar
I hate those cork gaskets, they are guaranteed to leak just about every time. BTW, it's strange, I don't even know you but your name is tattooed on my wrist (my daughter is named McKenna)
Old Apr 15, 2011 | 03:58 PM
McKenna's Avatar
Thanks Guys.
James- McKenna is my last name, yall picked a great name for the kid
Old Apr 15, 2011 | 03:59 PM
Ah, yeah thanks
Old Apr 16, 2011 | 07:41 AM
rustypigeon's Avatar
I personally use gaskets in all my automatic transmissions when servicing them. NAPA sells a rubber gasket for around $4. I have never had a gasket leak. I hate removing all the old silicon from the mating surfaces when using RTV sealants. The gasket solves the problem making future transmission servicing much easier.
Old Apr 16, 2011 | 09:12 AM
Team420's Avatar
another vote for rtv here. Every time I use the cork gaskets, I get about 2-5k miles and it starts leaking... the rubber gaskets from napa are ok, but its just easier to use the rtv... no lining up the holes for bolts, clean up is as easy as finding a razor blade. Even when I use a rubber gasket(per customer request) I use a thin layer of rtv to hold the gasket in place once its lined up.....
Old Apr 16, 2011 | 07:56 PM
scuba's Avatar
Damn, didn't know you were still around this place..
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
irritech
Jul 27, 2015 05:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
