95 4Runner Knock Sensor Help
I recently had my water pump, timing belt and radiator replaced, they also did a tune up. Upon picking up the truck before I get home ( less than 2 miles) the check engine light comes on. The light was never on before I took it to the Repair Shop. I take it back to the shop they say it is coming back as the Knock Sensor. They say that nothing they worked one would have caused this problem and say I will have to fork over more money to fix it? My question is this, is there anything they could have done while doing the above work to cause this problem?
Thanks
Thanks
hmmmm base on what you have specifically mentioned, nothing would have had an effect on the knock sensor wire. (That's the culpril most likely)
What did they do tune up wise?
Changing the KS sensor and wire out is child's play - well a mechanic's child's play! lol Pull the intake plenum the fuel rails, then the lower plenum and youll have access to the KS and KS wire.
I cant see how any of that would have done anything to the KS wire honestly. Look below the TB for a long black plastic cylinder (which is a wire connection) btwn the wiring harness and the lower plenum. pull it apart and look at hte connections, if they are corroded clean em, it may help.
sandyota
Feb 4, 2021 11:16 AM
