95 4runner hesitation
Old Oct 1, 2010 | 11:59 AM
keithguts's Avatar
I have a 1995 4runner with a 3.slow. It runs great when it is cold. As soon as it gets up to the right temp. and I step on the gass from a stop, it has some Hesitation. Once it passes the hesitation, it is fine. Any answers to the problem?
Old Oct 1, 2010 | 09:27 PM
the_supernerd's Avatar
I would check the temperature sensor first. The cold start injector system is something else to check. It could be something that is not temperature related, but just being hidden by fast idle. Maybe the TPS?
Old Oct 1, 2010 | 11:37 PM
85toyman's Avatar
I had the same problem with mine and turned out to be the TPS (throttle position sensor). I replaced mine and now it works great. Use 4crawler method for setting it correctly as well, getting it positioned correctly will make all the difference in how well your motor will run.
Good luck
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
colinmil
Jul 6, 2015 04:03 PM
