95 4runner
Old Feb 4, 2007 | 05:15 PM
tyndalltoy's Avatar
95 4runner
Hey gang. I'm a new member to this site, but i've visited here ever since i've been having trouble with the rig.(I'm also a first time toyota owner)I've been very happy with it so far,till now.Since it's the first one i've owned,it's probably an easy fix(so I thought)About 2 months ago, i started having a problem with the 95.When I came to a stop, it would idle rough, and as I accelerated, it had no power and would start to buck at 60 mph. The cel came on with a 25 code.I had cleared the code, and then it came on a few days later with a 25 and 26.You could smell unburned: gas at the exhaust.I found this site and started reading the threads.Lots of great reading. I then started to replace parts. Cap,rotor,fuel filter, air filter,plugs ,wiresand recently the MAF sensor with a used one.( NEW...$1400...NOT CHEAP).Even after all this,the cel still flashed a 25.I'm pretty much at wits end.Hopefully you guys can help me try to figure out this very frustrating problem which some of you probably dealt with at some point.
Old Feb 4, 2007 | 05:25 PM
91_4x4runner's Avatar
How is your timing?
Old Feb 4, 2007 | 05:34 PM
TFJ-4runner's Avatar
In 95 did they fix the head gasket problem on the 3.0?
Old Feb 4, 2007 | 06:14 PM
faubrunner64's Avatar
burnt valve how many miles are on it?
Old Feb 4, 2007 | 06:31 PM
littlerunner's Avatar
i agree on the burnt valve.have you dome a compression ck?that would likely be the next step
Old Feb 7, 2007 | 06:32 PM
tyndalltoy's Avatar
I brought to the toyota dealership the other day, and the mechanic told me I would probably have to change the O2 sensor because I was driving it while it was running rough and it could have plugged it up. He said it might clear itself out. I'll see how it goes for a couple days . If not , I'll change the O2 sensor.
Old Feb 8, 2007 | 04:25 PM
Tragic Drive's Avatar
My vote goes to check the compression before you throw any more money at parts . The symptoms you described sound like my 95 Runner when the exh valve was burnt .
The head gasket problems might have been fixed by 95 but the exhaust manifold design will still burn the valves.
Good luck
Old Feb 9, 2007 | 05:30 AM
tyndalltoy's Avatar
Good advise. I'll check the compression on the weekend......if it's not too cold.(-42 c )........oh to be in Mexico!!!!
Old Feb 9, 2007 | 08:01 AM
Marc's Avatar
This might help
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
