94runner rear lift
Old May 21, 2017 | 04:03 AM
Brahh!'s Avatar
94runner rear lift
New to yotatech! Lol but Anyone know of a solid good lift for the rear on a 94runner? Ive always dealt with leafs, Planning on putting a sas kit probably from tg roughly 3- 4in lift and looking for a rear coil kit thatll match. I believe itll be better than leafs idk but ive had a 95runner in the past 4in tg sas front and 5in springs in the rear but ive had alot of times one my rear tires would float and dont have the money to go full on 4link and all that good
stuff. But any info helps, just planning out what i need to get.
Old May 21, 2017 | 05:43 AM
dropzone's Avatar
Fossilized
https://www.yotatech.com/forums/f116...-guide-155339/
i went with FJ80 springs in the back, it is pretty bouncy/ I have all the stuff to convert to rear leaf springs. That will happen sooner or later.
Old May 21, 2017 | 06:32 AM
Brahh!'s Avatar
Thanks i checked it out, so youd rather run leafs instead of coils? Im just interested in the coils because i thought they flex more and itll keep my tires on the ground better..
Old May 21, 2017 | 10:25 AM
dropzone's Avatar
Fossilized
they flex great however unless you swap the links out for something beefier with bigger rod ends you run the risk of breaking the stock links. I have an extra set of uppers in the back just in case.
