94 runner brake light
brake light comes on when,
The E brake is on
Your low on brake fluid
and i think when your alt is going out.
Check your brake fluid level, that would be a start then check back here for any info.
The E brake is on
I would say low fluid....curious as to how you would you say his alt is going out??
My brake light stays on for a couple blocks after I've parked overnight with the e-brake on and its cold out. My fluid is clean and topped up. I worried about it for a while, but now I ignore it. If your brake fluid is in order, I wouldn't worry about it unless it stayed on all day.
Brake light+ battery light is your trucks way of telling you the charging system is not functioning properly. This usually means your alt is on its way out which often means the $10 brushes are worn out (easy fix).
Aleeex_u
Jun 5, 2016 06:52 PM
YotaGreenhorn
Jun 27, 2015 07:00 AM
