94 pickup v6 (vaccum hoses)???
Old Sep 24, 2010 | 01:24 PM
db8gsr's Avatar
hey everyone, i just recently took off the air intake chamber that sits on top of the intake manifold to replace my corroded/leaking water by pass hose. anyway before i removed all the vaccum hoses i labeled them with masking tape; however the tape didnt hold and now i am unsure of where each hose goes to. these are all the vaccum hoses on the passenger side off the engine bay that connect to the top intake maniold, can someone please help me figure out this puzzle of hoses?
thanks,
Old Sep 24, 2010 | 02:04 PM
SpecialScottie's Avatar
Check in a FSM. (factory service manual)
Old Sep 24, 2010 | 02:40 PM
DJ99's Avatar
Or on the sticker under the hood. Or this great old thread:
https://www.yotatech.com/forums/f116...erence-113572/
Old Sep 24, 2010 | 03:03 PM
Team420's Avatar
I usually just pull the plenum with the hoses attached, and lay it over to the side to avoid this problem, it's also a good idea to take pix of everything before you start a project like that, so you have a clear source of reference.....
That being said..... Look at the label under the hood, or in the fsm(as mentioned above), and if all else fails... find another rig to look at, and match them up... but make sure its the same year and has the same option.... there is quite a bit of difference between my 93 auto, and 94 5spd.
Old Sep 24, 2010 | 03:48 PM
MudHippy's Avatar
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
kcaudill
Oct 10, 2015 02:39 PM
the_supernerd
Oct 1, 2015 09:20 PM
taraf
Sep 25, 2015 02:57 PM
