94 pickup 6cyl / 4cyl banjo housing swap questions.
Old Dec 12, 2006 | 09:54 AM
highway74's Avatar
I have a 94 SR5 4x4 truck with 3.0. I know the V6 third member is different than the 4 cyl, but my question is, are the axles different as well? What about brake drums and axles or the banjo housing? I have a complete banjo housing from a 93 4cyl truck with axles/ brake drums etc, less the third member with low miles in great shape. Overall it is in much better shape than what I have, wondering if I could swap parts?
Old Dec 12, 2006 | 06:13 PM
trx125's Avatar
Axle housing should be the same just thirds are different!
Old Dec 12, 2006 | 07:40 PM
highway74's Avatar
Banjo
That's what I was thinking, is everything else listed the same? My truck has rear ABS and I imagine that the rear end I have is not, as it was from a 4 cyl. Are the ABS only different up front or are there ABS related parts in the rear? Axles and evrything else the same?
Old Dec 13, 2006 | 10:59 AM
highway74's Avatar
Pu
Come on guys, someone must have dealt with something similar to this?
Old Dec 13, 2006 | 11:08 AM
Bill's Avatar
As for the ABS stuff, why don't you just compair side by side? Everything should be the same. Unbolt the t-fitting on the brake line at the axle, and drop the axle. Then just bolt up the new one.
Old Dec 13, 2006 | 08:12 PM
highway74's Avatar
I have the spare stored at my mom's in her shed. I don't have access to it for a visual for a while as I won't be in that area. Thus can't do a side by side, which would be ideal. Still looking for thoughts on this before I make the trek to go get it.
YotaLogic
12
Nov 17, 2015 06:27 AM
ranma21
Jun 22, 2015 11:55 AM
AustinTaco
Jun 21, 2015 09:54 AM
TheManOutside
Jun 18, 2015 03:32 PM
