94 pickup 22re hard starting
Old Oct 16, 2016 | 04:27 PM
ttullio1's Avatar
I have a 94 pickup with a 22re. In the morning it starts fine, but after I shut it off, and start it right away, it'll start fine. But if I shut it off and wait 5-10 minutes it, like the time to fill the tank at the gas station, I cranks about 40 times before it'll fire. Wait 4-5 hours and it'll start fine. Any ideas? Possible bad injector bleeding down?
Old Oct 16, 2016 | 05:02 PM
Trents3.slow's Avatar
how long have these symptoms accrued? I don't know anything about the 22re models , but have a good common knowledge of engines.
Old Oct 17, 2016 | 01:56 PM
ttullio1's Avatar
It's been going on for about 2-3 weeks now.
Old Oct 17, 2016 | 05:23 PM
My only experience with this type of symptom resulted in a faulty ignition coil. This a classic case of "let it develop". Next time you get it to do the crank no start you should diagnose it. Pull a plug wire and see if it's getting spark.
When I had this issue on a completely different engine the coil would only fail when it was hot. And the best way to explain its cranking for a while before it would fire again is .......the coil would have to "stress" the spark plug gap in order for it to get back into working order. It will eventually just stop firing.
Like I said. This only past experience with a different engine. I hope this helps a little.
Sustainobile
Oct 5, 2023 07:50 PM
runnerC2
Aug 17, 2017 04:51 AM
colinmil
Aug 28, 2016 10:04 AM
fierohink
Jul 28, 2016 01:02 PM
95_n130
Jul 20, 2016 11:12 PM
