'94 3VZ engine valves replacement
Thanks Folks!
We will check all valve clearances before proceeding. I will need to find a good engine shop in Medellín, Colombia, where we are for a while. The one where we discovered the low-compression cylinder is not communicating well, I'm losing my confidence. I'll keep y'all posted.
Dieter
Dieter
The Toyota is now in the big Toyota dealer shop, called Autoamerica, in Medellín, Colombia; comparatively expensive, but best equipped. The engine is removed, and quite likely, we will do a complete rebuild.
Getting good-quality parts for the 3vz in Colombia is an issue only in that it may take a while... but I have more time than money (or sense? : )
Still, I'd like to explore what it would take to get the parts from the US. Colombian customs is a huge PITA, but it could work with a freight forwarder. I've surfed around a little bit for rebuild kits, etc, but would appreciate your recommendations... all of them, including those about the 3.4 swap. Far as I know, the 3.4 is not available in Colombia either; the 4.0 is.
Thanks!
Thanks!
