93 4Runner V6 3vze Diagnostic Not Working
Old Sep 8, 2019 | 11:02 PM
Newbie1991's Avatar
First time poster and only new to yotatech and glad I find the website thanks in advance to everyone.
I been having troubles with my 93 4Runner V6 Check engine light on(when driving it goes off and comes on and while its on car runs crap when off fine) I'm trying to get it to go into diagnostic mode I have connected a wire from TE1 to E1 but nothing will happen I made sure all accessories off the only thing is before I got it, it had been converted from auto to manual and I read that it has to be in neutral so I found the inhibitor switch and it's in neutral position and it's got me scratching my head as I can't get it to flash on dash to tell what to start with any guidance would be greatly appreciated.
Thanks
Old Sep 9, 2019 | 05:22 AM
scope103's Avatar
Start with the easy stuff. When you turn key-on (no jumper), does the CEL light solid?
With your multimeter, check for battery voltage to ground at B+ in the diagnostic connector. With key-off, check for continuity to ground at E1. Using a test light to ground, test W with the jumper in (you can use the multimeter, but you are looking for flashing. W is the same as the CEL.)
Old Sep 9, 2019 | 02:16 PM
Newbie1991's Avatar
Thanks mate no it doesn't only comes on once started gonna check the voltage and continuity and I will try with multimeter I let you know how I go cheers
Old Sep 9, 2019 | 05:15 PM
Newbie1991's Avatar
Alright no cel while key in on position only when jumper lead and test light in W cel on with key on
With key on voltage at B+ 12.30v
E1 has continuity
Tested W with test light while jumper in and key on it only makes wire inside test light glow red no actually light or flashing
MikeKaduce
Sep 1, 2013 12:47 PM
nickmeece
Apr 2, 2013 08:22 PM
Surfer
Nov 6, 2007 03:55 AM
