93 3vze - heater hose stuck
Old Jan 14, 2024 | 12:55 PM
Col's Avatar
Col
Does anyone know how to remove this hose, I’ve pulled the clamp off however if I pull on it, it won’t move. I have a replacement for it and it dosnt seem like it would go far back past the firewall
Old Jan 14, 2024 | 03:22 PM
snippits's Avatar
If you don't have a hose pick, take a utility knife, and cut it off slicing length wise. No need to dig the blade deep into the metal pipe. Just be easy with it. Done it many times.
Old Jan 15, 2024 | 05:02 AM
scope103's Avatar
A heat gun will relax the rubber and make it easier to get off. A hair dryer might work. You don't want to set anything on fire. If you want to save the hose (doesn't sound like you care), put your hand on the hose while heating it. If it's too hot for your hand it's probably too hot for the rubber.
Col
Jan 10, 2024 01:52 AM
donkadoodle
Jan 2, 2024 08:40 PM
coopster
Feb 13, 2021 11:17 AM
mussy01
3.4 Swaps
10
Mar 21, 2013 09:22 PM
lucky3
Aug 26, 2005 05:16 PM
