93 22re won't start after pumping gas
Old Oct 19, 2016 | 12:25 AM
Carlj64's Avatar
I started my 93 pickup with 22re at mh house, drove 3-4 miles and added 5 gallons of gas. Got back in and truck sort of fired up but quickly killed. Now all it does is crank over. I have sprayed fuel into the throttle body and checked the spark. Nothing. It doesn't even sound like it is even close to firing up.
Now, 2 days ago my alternator/water pump belt broke. I was 20 miles from home so I ran the truck till it got a little past the middle then stopped to let it cool down. I did that for 2 hours till I got home. I let a local shop replace the belt because I didn't have the time. I filled up the radiator before they worked on it because when the belt first popped the truck got ao hot it purged coolant out of the overfill tank. Today I ran it and added coolant. It ran fine. I let it sit then went to work. Stopped to get gas and you know the rest now.
I am not sure what to check.
Old Oct 19, 2016 | 06:32 AM
Carlj64's Avatar
Update:
Truck will not start when cold. AFM is turning on fuel pump. Fuel pressure is there. Spark plugs are dirty but nothing out of the ordinary.
