92 Toyota died on the road now wont start!!!
Old Dec 28, 2010 | 04:12 PM
big_boy_toy's Avatar
Hey guys first time posting here but have been checking out this sight on and off every since i got my truck and now i have run into a problem that I havent been able to solve..
92 toyota pickup V6. Was driving down the road and the engine light came on and just died. Turned over and nothing.. so on further investigation, I am getting spark, i am getting good fuel pressure all the way to the fuel rail by the intake manifold. I was looking at the Haynes manual and it steared me to the VSV. The valve works fine when applying 12v however when I took a reading from the connector that goes back to the On board computer there is no output.
any input would be great thx!!
Old Dec 28, 2010 | 08:20 PM
DJ99's Avatar
Have you checked the timing belt? It won't run very well without it.
Old Dec 28, 2010 | 08:24 PM
yes timing is good! i have been playing with this evening also and got the truck to run for 10 min when cold.. warmed up and then shutter down.. i got the error code read, it blinks once and then a second later 4 blinks, then repeat dont know what the codes mean yet still looking online, thx
Old Dec 29, 2010 | 05:20 AM
DJ99's Avatar
Code 14 is Ignition - Igniter or Coil.
Old Dec 29, 2010 | 05:59 AM
Cyberman's Avatar
You also checked the EFI fuse (and other fuses) too right?
Old Dec 29, 2010 | 08:19 AM
yes al fuses are good, i am gonna replace the igniter and see where that gets me..
Old Dec 29, 2010 | 01:45 PM
85toyman's Avatar
If your looking for coils and ignitors, let me know. I have a couple sitting on the shelf from 4runners that I parted out.
Old Dec 29, 2010 | 02:38 PM
so i have changed out the igniter and same problem, starts fine when cold and dies when hot, the same error code is spat out even after resting the comp with removing the EFI fuse for an hour, next thing is the coil i guess?
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
ibayne
Jun 26, 2015 06:30 AM
slider417
Jun 22, 2015 10:18 AM
