92 pick up not starting
Old Jul 6, 2021 | 08:37 PM
1992toyo's Avatar
I figured some may have experienced the same problems w your truck. The truck cranks but doesn’t want to start. It has a new battery. The COR is brand new. So I’ve checked voltage to the COR harness, and it is giving 10-11 volts at the blue wire . I know the fuel pump works because I ran a wire from the battery to the wire going to the fuel pump at the harness and she fires right up.12v direct.
I’m lost on why it only gives 10-11 volts at the blue wire at the COR. Any ideas?
Old Jul 7, 2021 | 06:33 AM
scope103's Avatar
Welcome to YotaTech.
Your post raises plenty of questions, all of which you can answer. Take a look at this post https://www.yotatech.com/forums/f116...-quits-312747/ for how to diagnose a fuel-related no-start.
The blue wire from the COR is to the fuel pump. While it depends on how you're doing your test (key-on? key to STArt? COR plugged in?) it sounds like a mis-seated COR.
Austin Dube
Jan 16, 2018 05:31 PM
LSD Rob
Nov 16, 2016 05:53 AM
DWEINBERG01
3.4 Swaps
12
Feb 5, 2011 02:16 PM
MAINEiac
Mar 12, 2009 10:32 AM
NMcruser
Apr 25, 2004 09:01 AM
