92 4runner auto to manual swap....
Old Nov 25, 2011 | 06:53 PM
Aaron d's Avatar
ok so it's been a while....
bracket welded super stiff
extended master cyl rod
extended slave rod
nothing works. or well.
when I extended the slave rod the clutch disengaged but wouldn't grab enough to hold...
when I extended the master rod nothing
bracket feels good and stiff now, even though it was not cracked.
so Im wondering if I have the wrong clutch,pressure plate, flywheel???
since these are the third ones they gave me since the other two sets were wrong.
so my plan now is to go down to the wrecker and get a stock clutch pressure plate and fly
and see if it works...
any other idears?
Old Nov 25, 2011 | 07:32 PM
Aaron d's Avatar
oh another question
how far does your clutch fork travel when pedal is engaged to the floor ?
mine moves about half an inch but looks like it could move a hole inch and a half?
Old Nov 26, 2011 | 07:35 PM
Aaron d's Avatar
come on guys cut me a bone here guys....
Old Nov 26, 2011 | 07:59 PM
BoostedRNR's Avatar
I don't know how far mine moves, but I can say that I've installed a few clutches that had defective pressure plates and had the same symptoms that you've listed. The fingers on the pressure plate were too weak and would flex, not allowing the plate to lift off the friction disk. Are you saying your slave cylinder is only pushing your fork a half inch?
Old Nov 26, 2011 | 08:46 PM
  #25
justin_4runner's Avatar
is the fork on the ball right? and the ball,nut not broke? and are u sure u have got all the air out of the system?
Old Nov 27, 2011 | 11:58 AM
  #26
Aaron d's Avatar
BoostedRNR "I don't know how far mine moves, but I can say that I've installed a few clutches that had defective pressure plates and had the same symptoms that you've listed. The fingers on the pressure plate were too weak and would flex, not allowing the plate to lift off the friction disk. Are you saying your slave cylinder is only pushing your fork a half inch?"
at the point where the slave meets the fork it only travels 1/2 inch.
I thought that was odd since my other vehicles slave cylinders move well over an inch .
if I have to take back this clutch assembly back again its going through there window lol.
but what you said sounds right as well...
justin_4runner "is the fork on the ball right? and the ball,nut not broke? and are u sure u have got all the air out of the system? "
fork is on the ball in correct location, everything is in good condition no bad wear or brakes, and the system is properly bleed over and over and over...
if somebody could eyeball there salve cylinder throw I would really appreciate it.
just to get an idea if its the master, slave or internal tranny issues.
Old Nov 27, 2011 | 12:04 PM
  #27
just measured mine and it only moved 1/2 inch. if u cant figure out the problem one of these weekends i can come over your way and see if i can help. u dont live too far from me.
and i have already did the same swap u are.
Old Nov 27, 2011 | 12:16 PM
  #28
Aaron d's Avatar
awesome thanks man !
I really appreciate it!
so I'm going with the wrong or bad pressure plate now...
I'm going to run down to the wrecker to see if I can find a stock used one to throw on and see if it works that should tell me whats up. I hope...
If I can't figure this out I'll give ya some gas money .
Old Nov 27, 2011 | 05:59 PM
  #29
have u thought that maybe u have the wrong throw out bearing? i know i went and got one from a store and it ended up being the wrong one they said there was two different ones.
Old Nov 28, 2011 | 05:34 PM
  #30
bmcghie's Avatar
I couldn't help but notice you said your pedal goes 1/4 the way to the floor before it starts to engage... I'm not sure exactly what distance is spec freeplay, but mine is set correctly and moves a bit more than an inch before it starts to engage.
If you haven't adjusted that... I'd do so before pulling the tranny again. Good luck!
Old Nov 30, 2011 | 01:27 PM
  #31
Aaron d's Avatar
i don't know?
I just used the one from the clutch plate set
Old Dec 11, 2011 | 01:11 PM
  #32
Aaron d's Avatar
well got it workin, finally...
it was a bad (soft) pressure plate. got a new clutch kit from marlin put it in and everything works great!
Thanks for every bodies input!
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Road Bull
Oct 10, 2015 04:55 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
ItsJustD
Jul 7, 2015 07:49 AM
