92 3vze - BTDC timing - what's acceptable?
Old Sep 30, 2007 | 08:23 PM
snelson's Avatar
Hey guys,
I'm correcting the timing on my engine after a HG replacement and following the FSM I've jumped the two connections and set the timing to 10 BTDC, but I noticed that it sounds better if bumped up to 12-ish, and some of the posts here suggest it'll improve low end 'pop'.
BUT none of the posts mentioned if this will do any damage - setting it to 12?
Engine is stock (heads were slightly decked during the HG replacement). It runs fine @ 10 but just sounded a little smoother @ 12...
It does stumble a bit when NOT under load, but I think this is just do to old original ignition wires, I'm replacing them soon.
Old Sep 30, 2007 | 08:30 PM
snelson's Avatar
Hey interesting, just noticed on another post that altitude plays a part in timing too - here in Calgary we're around 1200 meters (3500ft). Should I modify my BDTC accordingly??
A guy from Colorado posted "When was the last time you did cap/rotor/plugs/wires and checked the timing? You need to be AT LEAST 10*BTDC, I run 12* with no issues (but, again, I'm at altitude)"
Old Sep 30, 2007 | 08:31 PM
corvey's Avatar
What kind of head gasket you end up using?
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
