91 pickup blown engine repair
Old Jul 23, 2008 | 09:26 AM
santy's Avatar
Okay so my uncle gave me his 91 pickup and i ran it without oil and siezed the engine. i wanna rebuild it instead of replacing it. is there a way to unsieze it or what do i need to replace? its a 6 cylinder and only has somewhere around 200k on it, 5 speed. it has a new clucthc and i put money into it so i wanna try and get it running again.
Is there a guide or can anybody help with this? Thanks.
Old Jul 23, 2008 | 01:49 PM
olharleyman's Avatar
BUY A NEW LONG BLOCK it will be cheaper and the best option
Old Jul 23, 2008 | 02:11 PM
ILLINOISYOTADAWG's Avatar
your best opption is to just buy a long block a good rebuild kit with new bearing and pistons and gaskets+machine work could cost at least depending on your location and parts houses is going to cost at least 1.000 to 1.500.imo
Old Jul 23, 2008 | 02:33 PM
iselloil's Avatar
Check with sunwest in medical lake wa. The motor is trashed.
Old Jul 23, 2008 | 03:10 PM
abecedarian's Avatar
let's break this down-
seized engine- fubar crank main bearings... fubar connecting rod bearings... fubar engine.
cheaper to replace the block/crank/rods than to rebuild
Old Jul 23, 2008 | 03:50 PM
Crawdad's Avatar
Just replace that block, man. If the engine really seized up and didn't just spin a bearing or something, you're in for a ton of work. Screwed up cylinder walls from the heat, the crank is going to be trash, screwed bearings all around, who knows what else - you don't want to deal with that, trust me.
And for the sake of curiosity, how'd you manage to run it that long without oil?
Old Jul 23, 2008 | 03:52 PM
Cyberman's Avatar
From the way it sounds, the crank probably won't be able to be turned anyway. If it's seized, then the bearings are probably welded to the crank. I had one spun bearing, and it almost wasn't repairable.
Old Jul 23, 2008 | 05:04 PM
blueyoda's Avatar
How easy is it to swap from 3.0 to 22re? This is the perfect oppertunity to GO DEISEL. Or a lexus v8. Be patient and make it great!
matrad
Aug 26, 2024 08:21 AM
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
yourrealdad
7
Jul 21, 2015 08:53 AM
gog1968
Jun 22, 2015 05:55 AM
