91 pick up v6 revs fine after it bogs down and almost dies first
Old Oct 19, 2009 | 01:41 PM
travismillward's Avatar
Hey guys, just ran into an odd problem with my 91 toyota pickup (3.0 v6, manual).
So what happens is when i step on the gas pedal, the motor bogs down like it is going to die, it doesnt die it just takes a second and then revs up just fine, and if i'm already revving it has no problem. This just started happening today. Any thoughts?
Thanks!
Old Oct 20, 2009 | 06:32 PM
abecedarian's Avatar
may be a problem with the throttle position sensor, air flow meter or maybe a small leak in one of the intake duct boots.
Old Oct 21, 2009 | 11:07 AM
k, i'm gonna check those out.
here's an odd thing, the check engine light does not turn on.
also, yesterday when i got off the free way, the similar symptoms happened only this time the motor stalled and would not start, i pushed it off road, tried cranking the motor for a minute. it wouldn't start, then all of the sudden it started and ran just fine with seemingly more power then before? havent had the problem since! so odd...
Old Mar 29, 2010 | 12:39 PM
Nughuffer's Avatar
any updates on this? Having a similar issue with high idle and then stumble almost to stall.
Longbed 90
Mar 11, 2019 12:38 PM
mluz013
Sep 29, 2015 05:53 PM
utahman
Aug 23, 2015 02:04 PM
norcal98
Aug 10, 2015 06:20 AM
defrag4
Jul 31, 2015 10:50 AM
