91 4x4 about to drive me nuts...
Old Feb 19, 2009 | 07:06 PM
tcabner's Avatar
I'll jack it up tomorrow and try spinning the wheels to see if the hubs are engaged or not. If they are, I'll take them off, clean then regrease. However, if it is the hubs staying engaged, even if I fix that...I still do not want that noise going even when I'm in 4wd.
Old Feb 19, 2009 | 07:39 PM
tcabner's Avatar
Actually...I just got to thinking, as long as it's in 2wd and the hubs unlocked, shouldn't I be able to turn the shafts by hand with all four wheels on the ground?
Old Feb 19, 2009 | 08:18 PM
desconhecido's Avatar
I think so. I have a question: is it at all possible that the transfer case is not, in fact, in high 2wd but is in high 4wd? Then, if the hubs were disengaged, you'd have your axles rotating and your wheels rotating, but not at the same exact speed, necessarily. Would it generate noise for the hubs to be disengaged while the axles were being driven by the transfer case?
Old Feb 19, 2009 | 09:02 PM
tcabner's Avatar
Well, the cv shafts turn fine by hand in 2wd, hubs unlocked sitting on all four. I guess it's not the cv's, hubs, or the transfer case. It's got to be either the brakes or wheel bearings.
Old Feb 19, 2009 | 09:10 PM
  #25
abecedarian's Avatar
give up.
it's the oogie boogie man.
Old Feb 19, 2009 | 09:53 PM
  #26
BT's Avatar
BT
Sounds like U joints to me. And if you think it may be the speedo cable, it unscrews easily from the transfer case. Unscrew it and take a spin.
Old Feb 20, 2009 | 01:25 AM
  #27
TNRabbit's Avatar
OK, nobody has said the obvious here (besides the squeak); REPLACE THE DAMN CV BOOTS! Your CV joints won't last long with cracked boots....
Old Feb 20, 2009 | 05:08 AM
  #28
tcabner's Avatar
Yeah, I'm going to replace the cv boots when I have the rest pulled apart trying to fix whatever this damn noise is.
What kind of grease should I put back in there? Sorry for all the newb questions guys, this is my first adventure with 4x4's so bear with me, I really do appreciate the help.
Old Feb 20, 2009 | 05:35 AM
  #29
tysen86's Avatar
that narrows it down to only a couple of things. all of which are inside the wheel itself.
pull it apart and grease the bearings. its not that complicated and it might cure the prob.
Old Feb 20, 2009 | 05:37 AM
  #30
tysen86's Avatar
whatever you finally come up with, after you get it fixed make sure you post some action shots for us. 4wd is no good if you don't use it.
Old Feb 20, 2009 | 05:39 AM
  #31
1stgen4gunner's Avatar
I use 10W-40 motor oil for this kinda stuff, been working great so far.
Old Feb 20, 2009 | 06:19 AM
  #32
JShaffer0525's Avatar
turn the radio up jk.
Old Feb 21, 2009 | 05:11 AM
  #33
94svt50's Avatar
I also think its probably your speedometer cable. Mine sqeaks like crazy once you get rolling. Does your speedometer needle on gauge bounce a bit as your driving? Those pictures taken at EKU?
Old Feb 21, 2009 | 05:35 AM
  #34
aaron26889's Avatar
my friends truck did this... it was the cv joints he wanted to make sure thats what it was before he changed them so he stuck a grease gun in a tear in his cv boot and greased it ton. Then drove it around and the noise stoped so he bought new cv boots and put them on and all was well.
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
garagespace
Jul 9, 2015 08:37 AM
