90 3.0 motor direct swap into 93?
Blew my headgasket back in February. A guy is offering me a 90 3.0 fully rebuilt etc. Question is there anything on the 90 3.0 like connection types or wires changed on the 3.0 that would differ from 93 3.0
Most likely the computers will be different.
Any swap you run into wiring differences
Without sitting down doing this swap with both year EWD`s in your hands
If you install your engine harness with your ECU/ECM you should be good to go.
Meaning your putting just the( new to you) long block in your truck all the electrical and electronics is from your truck.
that should make things easier so your not repining connectors
Rickstwowheels
Nov 5, 2015 04:27 AM
