**89silverpu's e-locker retrofit build**
Old Jun 7, 2009 | 06:19 PM
  #41
89silverpu's Avatar
Originally Posted by highonpottery
good job man! i'm jealous of the e-locker. should paint your 3rd to match the freshly painted axle. also, too late now, but should have had the shop weld on some new shock mounts (for U-bolt flip) while they had it, especially if you're goin' down trails like fordyce. are those new CV bolts grade 8? they look like a regular grade bolt. i'd keep your stock ones around just in case - take a grinder to the ridges and they become bolts instead of studs. all us sac-vicinity YT'ers need to plan a trip for the summer!
Yeah I know i should have done that....I thought about it after the fact, I'll just do that later down the road, I'll run it like it is for now. They say 8.8 on them so I thought it was the metric equivalent? I may actually grind down the stock ones cause the new ones' bolt heads are a little too big to get a closed end wrench around. I just wanted to get out on the trail today, which I'll get some pictures of up in a little bit as for the trip planning, I'm already on it...
No one's bitten though lol
https://www.yotatech.com/forums/f15/...norcal-183832/
Originally Posted by 934rnr
Make sure you pull that non add shaft off your old diff and put it on the new one. It's a little extra work but worth it. The add shaft is less beefy than the non add. Trust me take it apart and see...
I though about it, but I didn't wanna deal with the axle seal etc...I may do that later down the road if it becomes a problem.
Old Jun 7, 2009 | 06:41 PM
  #42
89silverpu's Avatar
I went out wheelin up at Bob's place, and it was awesome!!! The truck did unbelievable with the gears and locker! Didn't get any good pictures, but here are a couple. There was a sick buggy up there with a 454 on pane and 1 tons and everything else you can think of. The trails up there are really gnarly and you need a tubed buggy or exocaged rig to not mess up your vehicle with the trees etc. I went on the outside loop that links all the trails together that is fairly easy, but very steep and definitely can feel the use of the locker!
Very steep!!!
Old Jun 8, 2009 | 08:24 AM
  #43
highonpottery's Avatar
i gave up on it for now as well. it's not only the seal, which i got, but i dry fitted it together and you'll need new bolts to mount the axle tube to the housing. the stock bolts (from the non-ADD) will bottom out in the holes of the 4.88 (ADD) diff before seating the flange.
without armor, i dunno if my truck is ready to hit fordyce yet. where's bob's place? is that the private OHV park in vacaville?
Old Jun 8, 2009 | 12:12 PM
  #44
89silverpu's Avatar
Yeah you definitely need armor for Fordyce, but you could forsure do Eagle Lakes/Signal peak just pick the right lines
Bob's is a up in the hills of Vacaville on a guy's private property. He's a great guy and lets anyone up there on Sundays. There's only a few little trails that a semi built truck can go on, most rigs are like that buggy, or exo'ed with dual transfercases locked front and rear, it's all super steep ravines climbin up the side of the mountains.
Old Jun 23, 2009 | 08:13 AM
  #45
89silverpu's Avatar
So I finally got my diff armor and got it welded on. I asked a question earlier about whether or not you should take out the third member....I was told by a couple people on pirate to leave it in because the clamping force from the studs holding the third in will prevent the axle housing from warping out of shape so easily. So I left it in and welded it on then changed the diff fluid to Royal Purple since the gears are done breaking in after a couple hundred miles. I also on a tab for a cb mount on my MC rear bumper real quick I'm lovin the new welder I got and am learnin pretty quickly
Old Jun 23, 2009 | 09:55 AM
  #46
874runnersr5's Avatar
looks good dude
Old Jun 23, 2009 | 06:05 PM
  #47
89silverpu's Avatar
Originally Posted by 874runnersr5
looks good dude
Thanks
Old Jul 8, 2009 | 01:08 PM
  #48
89silverpu's Avatar
Sorry for the quick write up, I'll go into more detail when I have more time!!
As promised, the writeup has been updated with a couple more pictures and some other more detailed information
Old Jul 24, 2009 | 04:07 PM
  #49
Nashman00's Avatar
i must warn you that you can break the locker really easy if you don't shorten you housing tubes use it wisely tell then i am on my second one and i did it right this time around
mine shorten half an inc so i have full spine engagemeant
Old Jul 28, 2009 | 10:10 PM
  #50
89silverpu's Avatar
I haven't had any troubles with mine at all yet. I've ran part of Fordyce once and Mix Challenge (mixchallenge.info) for the past 4 weekends straight and no problems, and it's been wheeled hard...I don't doubt the problem, but I don't think they'll break "easy" otherwise it'd be broken right now.
Old Dec 20, 2009 | 03:40 PM
  #51
tacho75's Avatar
how much was the total cost?
i want 1 of those (jealous)
Old Dec 20, 2009 | 04:26 PM
  #52
MuddfreaksOffroad's Avatar
so you just went and got a newer factory locker?
Old Dec 22, 2009 | 09:40 AM
  #53
89silverpu's Avatar
It was roughly $700, but that's with new gears as well.
yep...
Old Jan 22, 2010 | 07:16 AM
  #54
man this is awesome.. so stoked to get mine sunday
Old Jan 22, 2010 | 11:17 AM
  #55
Nashman00's Avatar
lol i have blown up 5 elockers in the last year
this timei split the carreio in half
sheader all the bolts off and twsied a tg cromo rear axle and took out the ring gear i am done with e lockers hellt he one big bareing can only be bought form toyota and there 100 bucks
there to pricey for me to fix now
Old Jan 23, 2010 | 08:11 AM
  #56
89silverpu's Avatar
I"ve had zero problems with mine and I've got dual cases and have run it hard. I love mine, seems like your gears or something were'nt set up right or your axle housing modification messed everything up. I know a couple people that run elockers as well and they love theirs too.
Old Jan 23, 2010 | 08:12 AM
  #57
89silverpu's Avatar
Again if you have any questions ask me....I think you tried to send me a pm but my inbox was full...sorry about that
Old Jan 24, 2010 | 05:49 PM
  #58
Still waiting for my bud to tell me to come over... grr the waiting kills
Old Jan 26, 2010 | 09:16 PM
  #59
WHOOOO!!! So stoked right now...
whats better than one elocker?
two.. hehe
Old Jan 26, 2010 | 09:24 PM
  #60
89silverpu's Avatar
Nice, what gears ya got in them? Too bad ya don't have a solid front to put the second to use...you gunna sell it or what?
