89 Rear main seal replacement
Old Dec 23, 2005 | 10:16 AM
bryanr's Avatar
I will be having my rear main seal replaced sometime in the upcoming month. I haven't called any shops yet, but roughly how many man hours or how much $ to replace is this typically? Is there anything else I should do while it's out? Would it be easier to put headers in while this is being done? Thanks.
Bryan
Old Dec 23, 2005 | 10:58 AM
suprathepeg's Avatar
All that has to be done is the shop will have to pull the tranny to get at the seal. From what I've heard its not so bad to do yourself in a day with standard tools.
Old Dec 23, 2005 | 11:03 AM
eric-the-red's Avatar
You might want to consider putting in a new clutch, if your's has some miles on it. It's a lot easier and cheaper while the tranny is out than doing it later.
Old Dec 23, 2005 | 11:07 AM
Elton's Avatar
changeing the clutch is a 4 hour job easy i did mine last week with a freind
Old Dec 23, 2005 | 11:37 AM
bryanr's Avatar
It's an Automatic transmission, so I'm not sure if there's anything I need to replace while it's down.
Old Dec 23, 2005 | 11:48 AM
Radyota's Avatar
Front tranny (torque convertor) seal for future insurance? If you don't mind replacing some fluid, that is.
Old Dec 23, 2005 | 11:52 AM
:pat: now that I read your sig I see that, Oh well forget about the clutch then
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
jennygirl
Nov 17, 2015 11:24 AM
Alaskan91
Sep 21, 2015 04:39 AM
cchinny
Jun 25, 2015 08:11 PM
