89 p/u 3.0 slave cylinder
Old Jan 8, 2014 | 06:24 PM
89Michael's Avatar
Slave cylinder runs compketely out of brake fluid. Is there a small leak? I refilled it about a month ago. And its out again should the lines be bled before? Or has it developed a hole somewhere? (I bought the truck a few months ago).
Old Jan 10, 2014 | 12:58 AM
wyoming9's Avatar
Red face
You need to find the leak?
You should be able to see where it is leaking .
If the slave cylinder is empty since this is the lowest point that is where the leak is.
If the leak is in the Master Cylinder the fluid stays in the lines below the leak.
when one fails it is best to replace both and the rubber hose.
Sep 4, 2015 09:27 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
wolfpackfan33
Aug 2, 2015 03:36 PM
