89 3.0 5speed help model
Old Mar 15, 2026 | 06:34 PM
Jose Pena's Avatar
Hey guys got in a car accident and the transmission wont go into any gear.
I was hoping to get a used imported transmission.
what model transmission so I need?
its a 2wd 3.0 5 speed.
a rebuild will be way out of my price range
Old Mar 15, 2026 | 08:57 PM
millball's Avatar
The ID plate code will tell you what transmission you need.
Either on the center firewall under the hood, or on the driver's door pillar depending on model year.
Old Mar 16, 2026 | 10:07 AM
aztoyman's Avatar
What millball said ^^ But, you should make sure it has serious damage before replacing it. It' may just be a shifter issue or something stuck inside that can be worked back into position. Is the case broken or cracked?
Old Apr 14, 2026 | 09:20 PM
Jose Pena's Avatar
I removed oil and no metal grinds was found
maybe if im lucky something moved around.
I could open it and take it to a shop. Would be cheaper or i could find the issue myself if im lucky. Ive never opened a transmission before
Old Apr 14, 2026 | 10:12 PM
aztoyman's Avatar
You DID find metal in the oil?
I have read posts of transmissions that were rebuilt and shipped and wouldn't go into gear. It was just from standing on end and getting rough handling that bound them up. Took a few thuds of persuasion to get them free. Maybe the impact of you accident made something stick?? I think it was on Marlin Crawler Forum that I read it. Call their shop.
The shifter bushings fall apart and cause shifting problems if they've never been replaced or upgraded.
Old Apr 15, 2026 | 12:15 AM
Jose Pena's Avatar
I did not find metal in the transmission oil.
Do you have a link for it? Thank you
Old Apr 20, 2026 | 11:10 AM
livergang's Avatar
If no metal, I say send it. Honestly sounds like it could be a linkage problem but if you’re pulling the trans potentially anyways, hitting it with a rubber mallet is an easy way to find out if it was just bound up slightly. If you can have someone turn the input or output shaft while you do that’ll maybe help persuade.
osi4
Apr 11, 2016 05:20 PM
Quarterbore06
Feb 5, 2011 08:57 AM
Junkers88
Jan 16, 2009 11:21 PM
